Scythe Mugen Compatibility List
Heimdall
So, da manche hier immer wieder fragen ob der Scythe Mugen auf ihr Mainboard passt habe ich bisschen bei google rumgesucht und das hier in einem Forum gefunden:
Due to a big demand for this list we are trying to keep this updated and accurate as possible. Please feel free to post images of possible and compatible motherboards.
The current list, which we try to keep up to date, can be also found in the Support corner of our website.
Color code:
Compatible
Not Compatible
Unkown
Mugen CPU Cooler
ASrock 939SLI32-eSATA2
ASRock P4i65G
ASRock 775Dual-VSTA
Abit AB9 QuadGT
Abit AW9D-MAX
Abit AW8D
Abit IB9
Abit AN8 SLI
Abit Fatal1ty AN9 32X
Abit AN9 32X
ABIT Fatal1ty FP-IN9 SLI
Abit IP35-E
Abit IP35
Abit IN9 32X-MAX Wi-Fi "Beast"
ASUS Commando
ASUS A8N-SLI Premium
ASUS A8R32-MVP
ASUS Striker Extreme
ASUS M2N32 SLI Deluxe
ASUS M2N-SLI Deluxe
ASUS M2N-E SLI
ASUS M2R 32 MVP
ASUS M2A-VM HDMI
ASUS M2R32-MVP
ASUS P5WD2-E Premium
ASUS P5B Deluxe
ASUS P5B
ASUS P5W DH Deluxe
ASUS P5N32-E SLi
ASUS P5N32-SLI Premium/WiFi-AP
ASUS P5LD2 Deluxe
ASUS P5N-E SLI
ASUS P5K Deluxe
ASUS P5K Premium
ASUS P5E ( )
AOpen i975xa-YDG
Biostar TA690G AM2 (Original AM2 retention is non-standard)
Biostar NF4 Ultra-A9A
DFI INFINITY P965-S
DFI LanParty NF4 Ultra D
Epox 8NPA + SLI
EVGA nForce 680i SLI
Gigabyte GA-965P-DQ6
Gigabyte GA-965P-DS4
Gigabyte GA-965P-DS3P
Gigabyte GA-P35-DQ6
Gigabyte GA-P35-DS4
Gigabyte GA-P35-DS3
Gigabyte GA-P35-DS3P
Gigabyte GA-P35T-DQ6
Gigabyte GA-N650SLI-DS4
Gigabyte GA-P35-DS3R (1st RAM Slot could be blocked)
Gigabyte GA-P35C-DS3R
Intel? D975XBX2
Intel
? D975XBX
MSI 975X Platinum V.2
MSI 975X Platinum
MSI 945PL Neo-F
MSI 945P Platinum
MSI 945P Neo-F
MSI 945GZM3-L
MSI P6N Sli Platinum
MSI K9A Platinum
MSI K9AGM
MSI K9NG Neo
MSI K9NGM2
MSI K9NGM2-FID
MSI K9NU Neo-V
MSI K9N Neo-F
MSI K9N SLI
MSI K9N SLI Platinum
MSI K9N Platinum
MSI K9N Platinum (PCB 1.1)
MSI K9N Ultra
MSI K9N Diamond
MSI K9VGM-V
PC-Chips A33G (Original AM2 retention is non-standard)
Last Update: 19.11.2007Every support is appreciated and would help other users as well so please feel free to supply any useful compatibility tips, pictures.
Disclaimer:
Please note that this compatibility may not apply to all the motherboards as the manufacturer randomly tend to change the components (capacitors, condensers, etc) used for their motherboard without informing to the public. Hence, the height of the capacitors and condensers maybe higher depending on the production lot of the motherboard.
Ich werde selber auch versuchen immer wieder reinzuschauen und es upzudaten, wenn denn interesse besteht. 😉
(Quelle: )
z0Ink
da war ich auch schon, nur leider wird mein MoBo (GigaByte Ga-P35-DS3 weder beim Mugen noch beim Mine Rev. B aufgeführt, somit bringt mir diese Seite nichts. Aber trotzdem danke das du das hier postest, soweit hab ich Egoist gar nicht gedacht.
KeKs
Wer sich mal die Mitgliederliste ansieht wird da eventuell den einen oder anderen wiedererkennen 😀
Gelöschter Nutzer 211
Die Kühlkonstruktion vom DS3 fällt abet wesentlich kleiner aus, daher würde ich mal davon ausgehen, dass der Infinity (Mugen hört sich ja sowas von beschissen an) dort passt.
Xtasy
jo aber der name musste leider kurzfristig geändert werden. mugen bedeuted irgendwas spezielles in der japanischen sprache
Horst58
Soll wohl sowas wie unendlich oder Unendlichkeit heißen ... was in Bezug auf Kühlleistung ja irgendwie doch passt.
z0Ink
Ja aber mir ging es um duie Kondensatoren die da sind. Und ich habe im Netz gelesen, das die da aufliegen und manchmal passt der /Infinity anscheinend auch gar nicht.
Heimdall
Ich habs mal hinzugefügt. Leider bin ich rot-grün blind mit einer sehr starken grün-Schwäche und finde nicht den richtigen grün-Ton... Also keine Beschwerden darüber bitte 😀
