Sansa e 260 Wiedergabeliste
matse
Hallo Leute,
ich hätte mal eine Frage, weiß einer von euch, wie ich bei meinem Sansa Ordner so speichern kann, dass sie später in der Liste "Wiedergabelisten" angezeigt werden? Bei mir gibts da nur diese to go liste.
Vielen Dank schonmal​
Moin,
soweit ich weiß ist man auf diese Liste beschränkt, bin da auch schon lange am probieren. Hab heut einfach mal ne Mail mit der Frage an Sandisk gemailt. Mal sehen was die sagen
Hello,
Thank you for contacting SanDisk Technical Support.
In MTP mode you can add playlists through Rhapsody, Napster, Yahoo, Music Match Jukebox, and Windows Media Player 10.
- Rhapsody:
Make sure device is showing as an "audio device" and in MTP mode.
Save a playlist (under the play tab in the mixer, select save)
Take that playlist and drag it to the sansa player in the top left had corner of the interface where the device shows.
Do not drag it to the transfer tab in the mixer as this will transfer the files only, not the playlist itself
- Napster :
Create or Save a playlist (bottom right of napster interface)
Under "My Playlists" on left of napster interface, right click the desired playlist, select "transfer playlist to portable device"
-Yahoo:
Follow the procedures in Yahoo to create a list and transfer it to device
-Music Match:
Create a playlist either by dragging files to the playlist manager or by right clicking the file in your library, send to>a playlist
Open the playlist manager (view>playlist manager)
Right click the playlist and select send to> portable device.
-Media Player 10:
Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
Select the Sync tab and click "Sync settings"
Check "Synchronize device automatically"
Set "View" to "All Playlists"
Place a check next to the playlists they want to transfer to device
Media Player should then sync those lists once you hit ok
Regardless of method, the playlist will now show on the mp3 player under menu>play music>Playlist
Best Regards,
Eric W.
EDIT: Auch im Winamp kann man Playlisten erstellen. in dem man im Media Libery Fenster einfach im Portable Device Menü einfach neue Playlisten erstellt. kinder einfach und funktioniert
