Problem with connecting ram heatsink to the mainboard asrock n68-gs4 fx usb3.0
NedoHR
I have problems with connecting this ram heatsink (EASYDIY ARGB RAM Kühler mit Controller RGB DDR Speicher Kühlkörper Kühlweste Fin Strahlung für DIY PC(kompatibel mit ASUS Aura Sync, GIGABYTE RGB Fusion und MSI Mystic Light Sync) Rot-2 Pack ) to this( )mainboard
I connect everything every cable and the last one 3 pin cable in 3 pin connector (CHA_FAN1) and RGB won't work there is no light I'm still searching for the solution but I can't find anything I would be really thankful to someone who helps me. Pls, guys help me!
Those are pictures of RGB, motherboard, cables.....etc
If you need some specific part to see what you cant find on picture pls let me know so I can provide you that part!
