Mainboard gesucht.
PetterJhon
Hello everyone ,,,
I'm looking for a new motherboard for my i5 3470th It should support all possible connections (ie USB3 internally and externally, PCIe 3.0x16, SATA 6GB / s) and be suitable for gaming.
Can anyone recommend me a motherboard, if that's not from AsRock, because I've made it rather bad experience.
New motherboards are no longer available for the old CPU socket. They are only needed second Hand Boards on ebay.
What's your problem with the old board?
Hello everyone ,,,
Thank you my issue has been solved,...
Hello everyone,
Can anyone recommend me a motherboard, if that's not from Asrock, because I've made it a bad experience.
See Post 2, there are no new motherboards for the old socket.
Hello everyone ,,,
I'm looking for a new motherboard for my i5 3470th It should support all possible connections (ie USB3 internally and externally, PCIe 3.0x16, SATA 6GB / s) mobdro lucky patcher kodi tools by experts used to
Hello PetterJhon,
I have found a used ASRock Z77 Extreme4 on Newegg. As I'm planning to upgrade from my fx 6300 in games like GTA v and other CPU intensive games, I have a used i5-3470 too (got it on eBay).
