Hohe fps Schwankungen bei CS 1.6
J0ghi
habe seit heute mal wieder CS 1.6 gezockt und bemerkt das ich zb bei buzzkill derbe Schwankungen hab von 100 auf 50 circa. Die Maus lässt sich dann nur noch schwerfällig bzw. schwammig bewegen.
Mein PC:
AMD Athlon XP 3200+ Barton
Asrock K7Upgrade-600
2048 Mb DRR Ram
80 Gb IDE Festplatte
ATI Radeon X800 Pro
und meine config:
// This file is overwritten whenever you change your user settings in the game.
// Add custom configurations to the file "userconfig.cfg".
unbindall
_cl_autowepswitch "0"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "0.000000"
bottomcolor "0"
brightness "1"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "2"
cl_cmdrate "101"
cl_corpsestay "0"
cl_crosshair_color "250 50 50"
cl_crosshair_size "small"
cl_crosshair_translucent "1"
cl_dlmax "756"
cl_download_ingame "1"
cl_dynamiccrosshair "0"
cl_forwardspeed "400"
cl_himodels "0"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Orange"
cl_logofile "Cb2"
cl_lw "1"
cl_minmodels "0"
cl_radartype "1"
cl_righthand "1"
cl_shadows "0"
cl_timeout "35"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "0"
con_color "255 180 30"
console "1"
crosshair "1"
fastsprites "0"
fps_max "101"
fps_modem "0"
gamma "3"
gl_dither "0"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "0"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "0.1"
hud_capturemouse "1"
hud_centerid "0"
hud_draw "1"
hud_fastswitch "0"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0"
lookstrafe "0"
m_filter "1"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "admin_ct"
MP3FadeTime "2"
MP3Volume "1"
mp_decals "30"
name "xxxxxx"
net_graph "3"
net_graphpos "1"
net_scale "5"
r_bmodelhighfrac "5.0"
r_detailtextures "0"
s_a3d "0.0"
s_automax_distance "30"
s_automin_distance "2"
s_bloat "2.0"
s_distance "60"
s_doppler "0.0"
s_eax "0.0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "5"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1"
s_verbwet "0.25"
sensitivity "12.520000"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.25"
sv_aim "1"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.85"
volume "1.460000"
setinfo "_cm_pw" "nitrox"
setinfo "friends" "1"
setinfo "_vgui_menus" "0"
setinfo "dm" "0"
setinfo "_ah" "0"
setinfo "ghosts" "0"
setinfo "lang" "de"
setinfo "rcf_upr" "101"
setinfo "nrate" "20000|101"
+mlook
+jlook
exec userconfig.cfg
Ich hoffe ihr könnt mir helfen 🙂
GreeZ
