Hilfe zu Adapterwahl
Helsinki
I would be interested to know how many adapters you need for a system in which a gpu and a cpu should be cooled.
if I'm not mistaken I need two adapters for gpu, cpu, pump, radiator and agb, which makes a total of 10. that means I would have to buy 10 of this: .
What I noticed , however, is that the gpu go down cooler, which means that it might be even better to take square adapter, can you confirm that?
1/4 inch seems to be the adapters of the standard !?
my imagination:
Pump Auquastream XT Ultraversion
radiator: Watercool MO-RA 2 Pro
agb: Magicool Plexiac 250 reservoir
cpu: EK Waterblocks EK-Supreme Plexi universal
gpu: is not fixed yet
