Help me decide which graphics card I should buy, please!
rickorton
I have a Gigabyte RTX 2070 8GB GAMING OC, but I could currently get a MSI GeForce RTX 2080 VENTUS for around the same price due to a sale, which I should get ?
I have a 1080p 144hz screen, i5-8400 and 16GB RAM.
Would the 2080 be overkill? Any other suggestions?
If the 2080 costs about the same as the 2070 there is no reason for not buying it. However the 2080 shouldn't be so much faster than the 2070 according to this don't worry about an "overkill" at graphic performance with the 2080. Maybe you could tell us which power supply you are using right now, because if your power supply is quite weak the greater power consumption of the 2080 could be a problem. Although there shouldn't be such a big gab betweeen these two cards it's just to be sure your not driving at the limit of the supply.
