Was wäre besser?
Despair
Liebe pc welt freunde,
ich hab mir letzte woche einen pc zusammen stellen lassen.
Ich hab jetz drin:
Name Intel Pentium E2180
Codename Conroe
Specification Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz
Package Socket 775 LGA (platform ID = 0h)
CPUID 6.F.D
Extended CPUID 6.F
Core Stepping M0
Technology 65 nm
Core Speed 1197.2 MHz (6.0 x 199.5 MHz)
Rated Bus speed 798.1 MHz
Stock frequency 2000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 10.0x
max VID 1.213 V
Features XD
____________________________________________________________-_
Northbridge Intel i945P rev. A1
Southbridge Intel 82801GB (ICH7/R) rev. A1
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Channels Single
Memory Frequency 332.6 MHz (3:5)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 21
_____________________________________________________________
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (7F7F7F58FFFFFFFF)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number TMS1GB264C081-665U
Manufacturing date Week 37/Year 07
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 333
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 15
TRC 12 16 20
DIMM #2
General
Memory type DDR2
Manufacturer (ID) (7F7F7F5800000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number TMS1GB264C081805AE
Manufacturing date Week 42/Year 07
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
Frequency (MHz) 266 333 400
CAS# 3.0 4.0 5.0
TRAS 10 12 15
TRC 14 18 21
Meine Grafikkkarte ist eine ASUS Geforce 7600 GS mit 512 Mb ram!
Nun in meiner bestellung war eig. ein Intel Core 2 Duo 1.8 Ghz Cpu drin ich wollte fragen welcher ist besser der 2ghz Dual core oder der andere?
Dann wollte ich noch fragen welche Grafikkarte besser ist eine Geforce 7600 GS oder eine Geforce 8500 GT ich hab die preise verglichen und die 7600 ist teurer.
Würde mich über eine antwort freuen
despair​
also meiner meinung nach ist der E2180 besser, da sich die 200MHz stärker als der 1mb cache auf die performance auswirken.
verrat uns doch mal dein budget, dann stellen wir die einen PC zusammen, vielleicht finden wir was besseres. denn so wie die beiden Prozessoren sind auch die beiden von dir genannten garfikkarten nicht wirklich ein kracher. von beiden ist die 7600 besser.
Schon gekauft!
Da ich erst 16 bin hab ich nebenbei im jugendzentrum für kinder computerkurse gegeben und das geld was ich zusammen hatte war 539€ und damit hab ich mir den pc zusammen stellen lassen. Aber ich hab gehört das die Core 2 Duo Prozessoren viel schneller arbeiten als die Dual Core oder gibts da garkeinen unterschied und hat mir der Händler ausversehen einen besseren Prozessor eingebaut?
Wieso ist die 7600 GS besser als eine 8500 GT die 8500 GT hat doch sogar DX 10 unterstüzung oder?
Mit freundlichen Grüßen,
Despair​
:btt:
Also Dein E2180 ist auf jeden Fall nicht besser als ein E4300
Der Cache macht schon einen sehr großen Unterschied, besonders wenn Du zocken willst...ich würde den Prozessortausch seitens des Herstellers nicht so hinnehmen. der E2180 ist obendrein auch noch billiger als der E4300
Bei der Grafikkarte solltest Du überlegen ob Dir nicht eine Oberklasse GF7 (z.B. 7900GT)nicht besser passt als die billige 8500GT
Hatte selbst ne 8600GTS und muss sagen, dass das das absolute Minimum ist, wenn man auch nur etwas vernünftig spielen will. Die 8500GT eignet sich bestenfalls für Multimedia-PC´s
Tauschen?
Also er hat mir gesagt er hat den anderen prozessor eingebaut weil er besser wäre und billiger aber viele haben mir gesagt das die core 2 duo Prozessoren besser sind.
Kann ich jetz zu ihm hingehen und ihm sagen das er mir den Prozessor einbauen soll für den ich eigentlich bezahlt hab?
Mfg Despair
Der E4300 ist ein Core 2 Duo,
der E2180 ist ein Pentium (der aber auf der Core-Architektur basiert)
Beide lassen sich in der Regel erstklassig übertakten...gab über beide Prozessoren Berichte mit OC ergebnissen in der PCGH.
Zum übertakten solltest Du vom Boxed-Kühler absehen und dir einen vernünftigen CPU-Kühler holen, ansonsten wird der arme kleine zu heiß und raucht Dir sehr schnell ab.
Und du solltes Dir auch mal das how2 zum C2D-übertakten durchlesen!
Bevor ich es vergesse: Der Chipsatz auf Deinem Mainboard ist auch nicht mehr der frischeste (i945)...ist zwar nicht unbedingt ungünstig zum Übertakten aber ein Board mit P35 Chipsatz wäre zeitgemäßer.
z.B. GA-P35-DS3
Hallo Despair,
Also wenn Du den 4300 auf 3 Ghz bringst, wird das einen ordentlichen Schub geben. Es mag vielleicht zu spät sein, aber wenn Du ein bisschen vernünftig gamen willst, sollte eine andere Grafikkarte gewählt werden.
Man kann jetzt nicht genau sagen was dan die Prese so machen.
Aber würde eine 8800Gt empfehln wird dan wohl 200€ kosten und nen Intel E8200 das sollte max 350€ dan kosten.
Ich glaube aber das die Preise dan so weit gesunken sind das du mit 320€ auskommst
