SWAT 4: Wie FullHD Auflösung (1920x1080) einstellen/erhöhen?
GästeFrage
Wie kann ich das Spiel Swat 4 in einer höheren Auflösung als w. 1600 spielen? Welche .txt Datei muss ich da verändern? Weiß das zufällig jemand?
Benutze Win 8.1 als Betriebssystem.
Das hat Google ausgespuckt:
SWAT 4 does not have native widescreen support. To use custom resolutions, navigate to \SWAT 4\Content\System and open Swat4.ini in a text editor such as NotePad.
For security reasons, on Vista 32-bit based systems, you will find the swat4.ini file at:
<boot-drive-letter>:&#92;Users&#92;<your-user-name>&#92;AppData&#92;Local&#92;VirtualStore&#92;P rogram Files&#92;Sierra&#92;SWAT 4&#92;Content&#92;System
On Vista 64-bit based systems, you will find the swat4.ini file at:
<boot-drive-letter>:&#92;Users&#92;<your-user-name>&#92;AppData&#92;Local&#92;VirtualStore&#92;P rogram Files (x86)&#92;Sierra&#92;SWAT 4&#92;Content&#92;System
Search for the following lines:
FullscreenViewportX=
FullscreenViewportY=
Modify these lines to suit your resolution. X is horizontal and Y is vertical.
The following example would force the game to run in the resolution of 1440x900.
FullscreenViewportX=1440
FullscreenViewportY=900
After changing the values, save the file and make it read only. This will prevent the game reverting back to a 4:3 resolution.
When launching and exiting the game you will get the error File Not Saved: Failed to write &#92;SWAT 4&#92;Content&#92;System&#92;Swat4.ini. This error is fine, just click OK to continue.
Some vertical view is lost when running in a widescreen resolution.
Quelle:
Wollte ich eben auch hinschreiben 😉.
<boot-drive-letter>:\Users\<your-user-name>\AppData\Local\VirtualStore\P rogram Files (x86)\Sierra\SWAT 4\Content\System
Ist übrigens als
"C:/Users/"dein Name"/AppData "[normalerweise ein versteckter Ordner]"/Local/VirtualStore/Program Files (x86)/Sierra/SWAT4/Content/System"
zu verstehen.
