systemwiederherstellung hab ich auch schon gemacht und mal nen anderen hdmi port beim tv ausprobiert jedoch ohne erfolg.
seltsame sache....
Daten:
CPU-Z version 1.51
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 5000+
Codename Brisbane
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
Package Socket AM2 (940)
CPUID F.B.1
Extended CPUID F.6B
Brand ID 4
Core Stepping BH-G1
Technology 65 nm
Core Speed 2611.8 MHz (13.0 x 200.9 MHz)
HT Link speed 1004.5 MHz
Stock frequency 2600 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 13.0x
max VID 1.400 V
Features XD, VT
K8 Thermal sensor yes
K8 Revision ID 6.0
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002008h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00060FB1 0x00020800 0x00002001 0x178BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00060FB1 0x000008D9 0x0000011F 0xEBD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x32582034 0x61754420 0x6F43206C 0x50206572
0x80000004 0x65636F72 0x726F7373 0x30303520 0x00002B30
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x02008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000007F
0x80000008 0x00003028 0x00000000 0x00000001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x00000002
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 I 64
KB 1 thread(s)
Cache descriptor Level 1 D 64
KB 1 thread(s)
Cache descriptor Level 2 U 512
KB 1 thread(s)
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000060
MSR 0xC0010015 edx = 0x00000000 eax = 0x02000048
MSR 0xC0010042 edx = 0x31061208 eax = 0x06120212
MSR 0xC0010041 edx = 0x00000001 eax = 0x00000812
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02002008h
0x00000001 0x00060FB1 0x01020800 0x00002001 0x178BFBFF
KB 1 thread(s)
KB 1 thread(s)
KB 1 thread(s)
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
Chipset
Northbridge NVIDIA MCP61 rev. A3
Southbridge NVIDIA MCP61 rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 326.5 MHz (
CPU/8)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 21
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Micron Technology (2C00000000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number 8HTF12864AY-667E1
Serial number D31FF9D5
Manufacturing date Week 25/Year 07
Attributes
Number of banks 1
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 333
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 15
TRC 12 16 20
DIMM #2
General
Memory type DDR2
Size 1024 MBytes
Serial number D31FF9BC
Attributes
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
DIMM #3
General
Memory type DDR2
Manufacturer (ID) Kingston (7F98000000000000)
Size 1024 MBytes
Part number 99U5316-001.A02LF
Serial number 660ED091
Manufacturing date Week 02/Year 08
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
DIMM #4
General
Memory type DDR2
Size 1024 MBytes
Serial number 490E7791
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 08 0E 0A 60 40 00 05 30 45 00 82 08 00 00
10 0C 08 38 01 02 00 03 3D 45 50 45 3C 1E 3C 2D 01
20 20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 EC
40 2C 00 00 00 00 00 00 00 08 38 48 54 46 31 32 38
50 36 34 41 59 2D 36 36 37 45 31 20 01 00 07 25 D3
60 1F F9 D5 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90
A0
B0
C0
D0
E0
F0
Dump Module #2
60 1F F9 BC 00 00 00 00 00 00 00 00 00 00 00 00 00
80
90
A0
B0
C0
D0
E0
F0
Dump Module #3
00 80 08 08 0E 0A 61 40 00 05 30 45 00 82 08 00 00
10 0C 04 38 01 02 00 03 3D 50 50 60 3C 1E 3C 2D 80
20 20 27 10 17 3C 1E 1E 00 00 3C 69 80 18 22 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 72
40 7F 98 00 00 00 00 00 00 05 39 39 55 35 33 31 36
50 2D 30 30 31 2E 41 30 32 4C 46 00 00 00 08 02 66
60 0E D0 91 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 39 39 55 35 33 31 36 2D 30 30 31 2E 41 30 32 4C
Dump Module #4
50 2D 30 30 31 2E 41 30 32 4C 46 00 00 00 08 02 49
60 0E 77 91 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model NARRA2 (0x1A6 - 0x61A840)
LPCIO
Vendor Fintek
Model F8000
Vendor ID 0x1934
Chip ID 0x581
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0x4
00
FF FF 00
FF FF FF FF 04
10
20 05 81 29 19 34 00 00 00
FF FF 74 30
FF 0F
FF FF
30 01
40
50
60 02 95
70 00
Hardware monitor
Hardware monitor ID=0x19340581 hardware monitor
Dump hardware monitor
LPC Register space, base address = 0x0290
00
FF 03 40 00
FF FF FF FF FF FF 00 00 55 4C 00
FF
10
20 D2 D4 C2
30
40
50
FF FF FF FF FF FF FF FF FF FF 05 08 10 19 34
FF
60 00 00 00
FF FF FF 00 00 00
FF FF FF FF FF FF 02
70 2B
FF 80
FF 1E
80 46 3C 64 55 64 55
FF FF FF FF FF FF FF FF 2A
FF
90 00 04 04 00 2A
FF 15
FF 44 02
FF 3F 55 05
FF 0A
A0 03 89 00 57 03 23 43 30 30 30
FF B6 57 57 57 9E
B0 06 45 00 57 03
FF 43 30 30 30
FF B6 57 57 57 9E
C0 0F
FF 00 A6 03
FF 3C 32 28 1E
FF D9 A6 80 66 0C
D0 0F
FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00
E0
F0 00 00 00 00 00 00 3D 3D 02 70
FF 00
FF FF FF FF
Hardware monitor
AMD Athlon 64 X2 5000+ hardware monitor
Temperature sensor 0 53°C (126°F) [0x142] (Core #0)
Temperature sensor 1 49°C (119°F) [0x133] (Core #1)
Hardware monitor
GeForce 8400 GS hardware monitor
Temperature sensor 0 59°C (138°F) [0x3B] (GPU Core)
PCI Device List
RAM Memory Controller
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0xFF
Int. Pin 0x00
Capabilities
HyperTransport Capability
Offset 44h
Revision 1.03
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 1000MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200MHz
Offset DCh
Interface type MSI Mapping
Dump
00 DE 10 EA 03 06 00 B0 00 A1 00 00 05 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3C 10 58 2A
30 00 00 00 00 44 00 00 00 00 00 00 00
FF 00 00 00
40 3C 10 58 2A 08 DC 20 02 20 00 11 11 D0 00 00 00
50 23 06 7F 00 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 00
70 44 44 44 00 D0 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 FA 00 64 0D 03 00 00 00 7F 00 00 00
90 78 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 01 A8
E0 00 00 E0 FE 00 00 00 00 07 00 00 00 20 10 00 00
F0 F0
FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E0
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 E0 03 0F 00 A0 00 A2 00 01 06 00 00 80 00
FF 00 00 00
40 3C 10 58 2A 00 F0
FF FE FA 3E
FF 00 FA 3E
FF 00
50 FA 3E
FF 00 00 5A 62 02 00 00 00 05 3F 00 1C 01
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00
FF FF C5 80 00 00 00 00 45 19 00 C0 00 30
80 09 10 00 8D 02 12 00 00 F0 00 40 01 F0 00 00 00
90 00 08 00 00 00 00 00 00 21 65 08 74 B9 0C 00 D0
A0 01 00 10 40 00 00 00 00 00 00 00 00 00 00 00 00
B0 90 02 EF 02 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 50 41 00 FE FD 01 00 B0
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03EB
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000FC00
Address 4 (port) 0x00001C00
Address 5 (port) 0x00001C40
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x07
Int. Pin 0x01
Capabilities
Power Management Capability
Offset 44h
Version 1.1
Dump
00 DE 10 EB 03 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 1C 00 00 41 1C 00 00 00 00 00 00 3C 10 58 2A
30 00 00 00 00 44 00 00 00 00 00 00 00 07 01 00 00
40 3C 10 58 2A 01 00 02 C0 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 10 00 00 01 14 00 00 01 18 00 00 00 00 00 00
70 00 00 00 00 00 00 C8 FE 00 00 FE FE 01 20 00 00
80 00 10 FE FE 00 00 00 00 00 00 00 00 00 00 00 00
C0 D4 30 80 01 01 00 00 00 00 00 00 00 00 00 00 00
D0 40 00 40 01 10 00 00 00 05 00 00 00 00 00 00 00
E0 00 10 04 00 44 40 00 07 80 22 00 20 77 44 44 11
F0 02
FF 1E BF 01 00 00 80 10 00 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03F5
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 F5 03 00 04 A0 00 A2 00 00 05 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 10 02 80 10 10 00 10 10
50 10 10 10 10 00 00 00 00 00 00 00 00 10 42 00 00
60 0B 00 00 00 C0 1C 52 06 21 00 10 0A 00 00 63 00
70 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 40 00 00 00 00 00 A0 18 00 00
90 00 00 00 00 00 00 00 12 20 81 04 00 00 00 00 00
A0 00 14 00 06 00 00 00 00 00 00 00 00 01 00 00 00
B0 00 00 00 00 42 80 30 04 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
USB Controller (OHCI)
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F1
Revision ID 0xA3
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE02F000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 F1 03 06 00 B0 00 A3 10 03 0C 00 00 80 00
10 00 F0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 03 01
40 3C 10 58 2A 01 00 02 FE 00 00 00 00 00 00 00 00
50 26 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F2
Revision ID 0xA3
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE02E000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x17
Int. Pin 0x02
Capabilities
Debug Port Capability
Offset 44h
Offset 80h
Version 1.1
Dump
00 DE 10 F2 03 06 00 B0 00 A3 20 03 0C 00 00 80 00
10 00 E0 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 03 01
40 3C 10 58 2A 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 83 12 0F 01 00 00 00 00
70 00 04 08 05 00 10 20 80 89 3D B6 22 77 25 44 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 01 00 20 00 C0 00 00 00 00 00 00 00 00
B0 00 11 22 33 44 00 00 00
FF 03 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F3
Revision ID 0xA1
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Subsystem Vendor Capability
Offset B8h
Subsystem ID 0x2A58
Sub. Vendor ID 0x103C
Offset 8Ch
Dump
00 DE 10 F3 03 07 04 B0 00 A1 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 B0 B0 80 22
20 E0 FD E0 FD D0 FD D0 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00
FF 00 04 02
40 00 00 73 07 01 00 02 00 07 00 00 00 00 00 4C 00
50 00 00 00 00 00 00 00 00 FE 1F
FF 1F 00 00 00 00
80 00 06 00 00 00 00 00 00 00 00 00 00 08 00 01 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00
FF FF 00 00 0D 8C 00 00 3C 10 58 2A
C0 3C 10 58 2A 07 00 00 00 00 00 00 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F0
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFE024000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x17
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Message Signalled Interrupts Capability
Offset 50h
Offset 6Ch
Dump
00 DE 10 F0 03 06 00 B0 00 A2 00 03 04 00 00 80 00
10 00 40 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 02 05
40 3C 10 58 2A 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 03 A8
F0 00 00 00 00 00 00 00 47 00 29 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EC
Revision ID 0xA2
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000F000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 EC 03 05 00 B0 00 A2 8A 01 01 00 00 00 00
20 01 F0 00 00 00 00 00 00 00 00 00 00 3C 10 58 2A
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 3C 10 58 2A 01 00 02 00 00 00 00 00 00 00 00 00
50 02 F0 00 00 00 00 00 00 A8 A8 A8 A8 AA 00 99 99
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
Bridge device
bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03EF
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE02D000
Address 1 (port) 0x0000EC00
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset 50h
Offset 6Ch
Dump
00 DE 10 EF 03 07 00 B0 00 A2 00 80 06 00 00 00 00
10 00 D0 02 FE 01 EC 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 01 14
40 3C 10 58 2A 01 50 02 FE 00 01 00 00 08 00 00 20
50 05 6C 86 01 00 00 00 00 00 00 00 00 00 00 00 00
FF 00 00 00 08 00 03 A8
F0 00 00 00 00 00 00 00 00 42 01 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x000009F0
Address 1 (port) 0x00000BF0
Address 2 (port) 0x00000970
Address 3 (port) 0x00000B70
Address 4 (port) 0x0000D800
Address 5 (memory) 0xFE02C000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
00 DE 10 F6 03 07 00 B0 00 A2 85 01 01 00 00 80 00
10 F1 09 00 00 F1 0B 00 00 71 09 00 00 71 0B 00 00
20 01 D8 00 00 00 C0 02 FE 00 00 00 00 3C 10 58 2A
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 03 01
40 3C 10 58 2A 01 B0 02 00 00 00 00 00 00 00 00 00
50 2F 68 08 00 00 00 00 00 A8 A8 A8 A8 AA 00 99 99
60 00 00 00 00 41 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
80 00 00 00 C0 00 20 2B DF 00 10 08 94 DE 7F FB 5E
90 00 00 E9 3E 00 00 00 00 06 00 06 10 F6 03 01 01
A0 08 00 00 0F 80 00 00 00 00 00 00 00 33 31 00 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 03 A8
D0 08 00 00 77 00 08 03 00 08 00 00 42 00 08 00 00
E0 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 8 (0x08), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03F6
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x000009E0
Address 1 (port) 0x00000BE0
Address 2 (port) 0x00000960
Address 3 (port) 0x00000B60
Address 4 (port) 0x0000C400
Address 5 (memory) 0xFE02B000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
10 E1 09 00 00 E1 0B 00 00 61 09 00 00 61 0B 00 00
20 01 C4 00 00 00 B0 02 FE 00 00 00 00 3C 10 58 2A
30 00 00 00 00 44 00 00 00 00 00 00 00 15 02 03 01
80 00 00 00 00 F8 E5 DD 7F 00 00 5A 15 D6
FF CA 7D
90 00 00 DD 03 00 00 00 00 06 00 06 10 F6 03 01 01
A0 08 00 00 00 80 00 00 00 00 00 00 00 33 31 00 02
D0 08 00 00 44 00 08 08 00 08 00 00 44 00 08 08 00
PCI to PCI Bridge
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E8
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x2A58
Offset 48h
Version 1.1
Offset 50h
Offset 60h
PCI Express Capability
Offset 80h
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Dump
00 DE 10 E8 03 07 04 10 00 A2 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 A1 A1 00 00
20 00 F8 F0 FB 01 E0 F1 EF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 1C 00
40 0D 48 00 00 3C 10 58 2A 01 50 02 F8 00 00 00 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 70 49 00 00
60 08 80 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 01 3D 11 00
90 40 00 01 31 80 25 08 00 C0 01 48 01 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03E9
Revision ID 0xA2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x08
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x2A58
Offset 48h
Version 1.1
Offset 50h
Offset 60h
Offset 80h
Port 1
Version 1.0
Physical slot #0
Presence detect no
Link width 1x (max 1x)
Dump
00 DE 10 E9 03 07 04 10 00 A2 00 04 06 08 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 91 91 00 00
20 C0 FD C0 FD B1 FD B1 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 04 00
50 05 60 93 00 0C 30 E0 FE 00 00 00 00 60 49 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 11 3C 11 01
90 00 00 11 10 00 05 10 00 C0 01 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Revision 1.02
Interface type Host/Secondary
Device number 0
Dump
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 01 00 E4 00 00 00 20 C8 20 0F 0C 00 00 00
80 08 00 01 21 20 00 11 11 22 06 75 80 02 00 00 00
90 69 01 61 01 00 00 03 00 07 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 1F 01 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 0A 00 00 00 0B 00 00 00 00 00 00 00 00 00 00
90 03 00 E0 00 00
FF EF 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 03 00 F4 00 00 02 FE 00
B0 03 00 F0 00 80 3F F0 00 00 00 00 00 00 00 00 00
C0 13 90 00 00 00 F0 00 00 00 00 00 00 00 00 00 00
E0 03 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00
F0 01 20 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 00 00 00 00 01 00 80 00 01 00 C0 00
60 E0 3F 78 00 E0 3F 38 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 46 00 00 00 00 00 00 00
80 25 00 00 00 00 00 00 00 24 C2 6A 0C 20 13 A2 00
90 10 0C 01 00 5A 80 10 A7 24 00 00 80 20 22 2A 00
A0 EF 02 00 0C 00 00 00 00 00 00 00 00 00 00 00 00
B0 DB F7 6A B3 0A 00 00 00 DF 4E C8 85 E2 2C 80 1E
C0 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 E2 37 86 01 B8 9B 2D E5 D8 2E F0 D0 CE BE E2 F5
E0 FB DA 43 0D CA 9A F8 32 F8 37 D7 DA 23 1E E8 D5
Host Bridge
bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Secure Device Capability
Offset F0h
Dump
00 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40
FF 3B 04 00 40 00 10 0A 00 00 00 00 00 00 00 00
50 E0 E7 49 4D D3 00 00 00 00 00 00 00 80 F3 63 24
60 F3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 11 01 32 51 21 40 70 50 00 2A 00 08 17 21 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 00 00 00 00 99 0D 00 00 D0 10 A8
FF 00 00 00 00
D0 00 00 00 00 01 A7 0D 00 00 00 60 08 26 26 26 00
E0 00 00 00 00 3E E0 50 00 19 17 00 00 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 B1 0F 06 00
OHCI FireWire Controller
bus 1 (0x01), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x11C1
Model ID 0x5811
Revision ID 0x70
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x08
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFDEFF000
Subvendor ID 0x103C
Subsystem ID 0x2A58
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 C1 11 11 58 06 00 90 02 70 10 00 0C 08 20 00 00
10 00 F0 EF FD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 13 01 0C 18
40 00 00 00 00 01 00 02 7E 00 80 00 00 00 00 00 00
70 00 D8 11 00 13 EC 62 01 00 00 00 00 00 00 00 00
80 00 D8 11 00 13 EC 62 01 00 00 00 00 00 00 00 00
VGA Controller
bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0422
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x08
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFA000000
Address 1 (memory) 0xE0000000
Address 3 (memory) 0xF8000000
Address 5 (port) 0x0000AC00
Subvendor ID 0x1043
Subsystem ID 0x050A
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
Offset 68h
Offset 78h
Device type PCI-E Endpoint Device
Port 0
Version 1.0
Dump
00 DE 10 22 04 07 00 10 00 A1 00 00 03 08 00 00 00
10 00 00 00 FA 0C 00 00 E0 00 00 00 00 04 00 00 F8
20 00 00 00 00 01 AC 00 00 00 00 00 00 43 10 0A 05
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
40 43 10 0A 05 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 01 00 E0 84 00 00
80 10 28 00 00 01 3D 01 00 48 00 01 11 00 00 00 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 5.11
date 07/16/2007
DMI System Information
manufacturer HP-Pavilion
product GJ390AA-ABD a6142.de
version unknown
serial CZH7350BN1
UUID 00ABB379-2FC71210-9A8E8844-CF0C0D39
DMI Baseboard
vendor ASUSTek Computer INC.
model NARRA2
revision 2.00
serial MS1C77S31500110
DMI System Enclosure
manufacturer Hewlett-Packard
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer AMD
model AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
clock speed 2600.0 MHz
FSB speed 200.0 MHz
multiplier 13.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 1024 MBytes
DMI Memory Module
designation A0
size 1024 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
size 1024 MBytes (double bank)
DMI Memory Module
designation A3
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCIEX16
type A5
populated yes
DMI Extension Slot
designation PCIEX1_1
type A5
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation A3
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI OEM Strings
string[0] bid=73DEv3PrA2;PROD_MSWORKS;SFCHK;DLED;IS.N60d;ACP wrFail=Off;Cha
string[1] n=Retail;CPUFan=On;DVDRW;LegacyFloppy=No;TVout=PAL ;PCBRAND=Pavil
string[2] ion;
OS=MSV;KBDRV;LScribe;Vos.P;PROD_MSOFFHST;HDMI; MDVD_B;RC_B;FP
string[3] A=HML;C_VEN;.ra;##HPCPC=00000000<90000006020000000 42000025351413
string[4] 0040000010001000;5;:0665<;85>18>1<2=1:<55>?4;;=?=1 9:<8494;>:8011
string[5] <=31953=?76?>378139;594701:=;34:;55;9128<7937==0<7 22<:<1:2489>:0
string[6] 88=6:?1;2>8=8>12691>>286:9?;4454>3<3>89909>=738375 ;02951<;>=??2?
string[7] 70>75;04<815:33<20846?312127;?24876>7488457<0;0?39 >9;?407;8;8;09
string[8] >=;==>231>;?456:100000006;00000000002000840515?454 =435<49434=234
string[9] 05347594>444?4753502000000000000000000000000000000 0000000000?24?
string[10] 41954<8?4243:463542:9034;??09<31;8951=>:><6>3291=3 5:7;:7?<0;=973
string[11] 478<4:062629<>53103<<=4651<3499:7?769::98;357697=: 3483>07=6;>1<1
string[12] ?<>7<817?5586>79?5:5?19<87:>=6507148017=835>552096 ;714776===1=59
string[13] :5:9;7?16>;910;6<?>4?;=21?;7975:6660><>729>:9<98<5 <=991>7?7>
string[14]
string[15]
Display API(s)
NVIDIA direct I/O API
NVAPI display API
Display Adapter(s)
Device number 0
Name GeForce 8400 GS
Vendor ID 0x10DE (0x1043)
Model ID 0x422 (0x50A)
Revision ID 0xA1
Perf Level Default
GPU core clock 459.0 MHz
GPU memory clock 400.0 MHz
Perf Level 2D Desktop
Perf Level 3D Applications
GPU temperature 59 C
Display I2C
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition (Build 6000)
DirectX Version 10.0
Resources
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0x1C00
Port I/O Space, BA=0x1C40
Memory I/O Space, BA=0x00000000FE02F000
Memory I/O Space, BA=0x00000000FE02E000
Memory I/O Space, BA=0x00000000FE024000
Port I/O Space, BA=0xF000
Memory I/O Space, BA=0x00000000FE02D000
Port I/O Space, BA=0xEC00
Port I/O Space, BA=0x9F0
Port I/O Space, BA=0xBF0
Port I/O Space, BA=0x970
Port I/O Space, BA=0xB70
Port I/O Space, BA=0xD800
Memory I/O Space, BA=0x00000000FE02C000
Port I/O Space, BA=0x9E0
Port I/O Space, BA=0xBE0
Port I/O Space, BA=0x960
Port I/O Space, BA=0xB60
Port I/O Space, BA=0xC400
Memory I/O Space, BA=0x00000000FE02B000
Memory I/O Space, BA=0x00000000FDEFF000
Memory I/O Space, BA=0x00000000FA000000
Memory I/O Space, BA=0x00000000E0000000
Memory I/O Space, BA=0x00000000F8000000
Port I/O Space, BA=0xAC00
Port I/O Space, BA=0x1008, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
