System Information
Time of this report: 11/12/2007, 00:06:59
Machine name: BLUBBORIZER
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: German (Regional Setting: German)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: MS-7125
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 4000+, MMX, 3DNow, ~2.4GHz
Memory: 2048MB
RAM
Page File: 254MB used, 3685MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: MSI NX7900 GS(NVIDIA GeForce 7900 GS)
Manufacturer: NVIDIA
Chip type: GeForce 7900 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0292&SUBSYS_06641462&REV_A1
Display Memory: 512.0
MB
Current Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/17/2007 01:07:00, 5783040 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/17/2007 01:07:00, 6853088 bytes
Device Identifier: {D7B71E3E-41D2-11CF-316F-6F2600C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0292
SubSys ID: 0x06641462
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_10DE&DEV_0059&SUBSYS_75851462&REV_A2
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.6090 (English)
WHQL Logo'd: Yes
Date and Size: 5/19/2006 08:44:52, 3965056 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 26, 24
Static/Strm HW 3D Bufs: 26, 24
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft® Digital Media Pro Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x00B0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x10DE, 0x005A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 4/2/2003 13:00:00, 4736 bytes
+-+ USB-HID (Human Interface Device)
| | Vendor/Product ID: 0x05E3, 0x1205
| | Matching Device ID: usb\class_03&subclass_01
| | Service: HidUsb
| | Driver: hidclass.sys, 8/3/2004 23:08:20, 36224 bytes
| | Driver: hidparse.sys, 8/3/2004 23:08:18, 24960 bytes
| | Driver: hid.dll, 8/4/2004 00:57:22, 20992 bytes
| | Driver: hidusb.sys, 4/2/2003 13:00:00, 9600 bytes
| +-+ HID-konforme Maus
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouclass.sys, 8/4/2004 00:37:42, 23552 bytes
| | | Driver: mouhid.sys, 4/2/2003 13:00:00, 12288 bytes
Gameport Devices
PS/2 Devices
+ HID-Tastatur
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:46:12, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 00:46:10, 25216 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:58:36, 40840 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: LAN-Verbindung - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-
PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 7.3
GB
Total Space: 13.2
GB
File System: NTFS
Model: Maxtor 6Y080P0
Drive: D:
Free Space: 76.8
GB
Total Space: 114.5
GB
File System: NTFS
Model: SAMSUNG SP1213C
Drive: E:
Free Space: 60.5
GB
Total Space: 65.0
GB
File System: NTFS
Drive: F:
Model: TSSTcorp DVD-ROM TS-H352A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (German), 8/3/2004 22:59:54, 49536 bytes
Drive: G:
Model: _NEC DVD_RW ND-3540A
System Devices
Name: MSI NX7900 GS(NVIDIA GeForce 7900 GS)
Device ID: PCI\VEN_10DE&DEV_0292&SUBSYS_06641462&REV_A1\4&243 D7BD0&0&0070
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6853088 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 5783040 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9147 (), 8/11/2006 14:45:20, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 364544 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6746112 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 8491008 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11117 (English), 9/17/2007 01:07:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6344704 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 5509120 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 3334144 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 3166208 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 1150976 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 3551232 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 3629056 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 2371584 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 2441216 bytes
Driver: C:\WINDOWS\system32\msicpl.dll, 1.00.0001.6674 (Chinese), 10/3/2006 07:36:38, 1593344 bytes
Driver: C:\WINDOWS\system32\Nvgpio.dll, 2.00.0000.0001 (English), 6/1/2006 10:22:00, 53248 bytes
Driver: C:\WINDOWS\system32\sw20.exe, 1.00.0000.0001 (Chinese), 9/7/2006 11:13:50, 208896 bytes
Driver: C:\WINDOWS\system32\sw24.exe, 9/7/2006 11:14:42, 69632 bytes
Driver: C:\WINDOWS\system32\WinSys.exe, 1.00.0000.0002 (English), 9/7/2006 11:12:40, 200704 bytes
Driver: C:\WINDOWS\system32\WinSys2.exe, 1.00.0000.0001 (English), 10/3/2006 07:37:44, 217088 bytes
Driver: C:\WINDOWS\system32\sysinfo.sys, 6/1/2006 10:22:00, 8192 bytes
Driver: C:\WINDOWS\system32\sysinfoX64.sys, 6/1/2006 10:22:00, 9728 bytes
Driver: C:\WINDOWS\system32\sysinfo.vxd, 6/1/2006 10:22:00, 8883 bytes
Driver: C:\WINDOWS\system32\sysinfo.dll, 1.00.0000.0247 (Japanese), 6/1/2006 10:22:00, 114688 bytes
Driver: C:\WINDOWS\system32\HookShield.dll, 10/5/2006 08:45:12, 262144 bytes
Driver: C:\WINDOWS\system32\HookMAp.dll, 10/5/2006 08:45:50, 253952 bytes
Driver: C:\WINDOWS\system32\Auxiliary.dll, 8/14/2006 04:31:06, 32768 bytes
Driver: C:\WINDOWS\system32\msvcr71.dll, 7.10.3052.0004 (English), 2/21/2003 13:42:22, 348160 bytes
Driver: C:\WINDOWS\system32\d3dx9_27.dll, 9.08.0299.0000 (English), 7/22/2005 12:59:00, 2319568 bytes
Driver: C:\WINDOWS\system32\d3dx9_28.dll, 9.10.0455.0000 (English), 12/5/2005 11:09:18, 2323664 bytes
Driver: C:\WINDOWS\system32\smdll.dll, 1.00.0000.0001 (Chinese), 7/12/2006 22:00:04, 131072 bytes
Driver: C:\WINDOWS\system32\MadCHook.dll, 2.02.0002.0005 (English), 7/21/2006 04:33:58, 128512 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 8/11/2006 14:43:06, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 8/11/2006 14:43:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 8/11/2006 14:42:44, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 8/11/2006 14:42:44, 35840 bytes
Name: nForce4 HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_71251462&REV_A4\3&241 1E6FE&0&00
Driver: n/a
Name: PCI Standard-PCI-zu-PCI-Brücke
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&241 1E6FE&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (German), 8/4/2004 00:37:14, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&241 1E6FE&0&68
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&241 1E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&241 1E6FE&0&58
Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_A2\3&241 1E6FE&0&48
Name: Standard erweiterter PCI-zu-USB universeller Hostcontroller
Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_71251462&REV_A4\3&241 1E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (German), 8/4/2004 00:57:38, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:57:22, 7168 bytes
Name: Standard OpenHCD USB-Hostcontroller
Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_71251462&REV_A2\3&241 1E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 17024 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_10DE&DEV_0059&SUBSYS_75851462&REV_A2\3&241 1E6FE&0&20
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (German), 8/4/2004 00:57:24, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (German), 8/4/2004 00:58:24, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (German), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (German), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:58:28, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.6090 (English), 5/19/2006 08:44:52, 3965056 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0052 (English), 3/2/2006 00:22:04, 577536 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0060 (English), 5/19/2006 01:01:32, 18796544 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 06:54:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0060 (English), 5/11/2006 00:18:36, 10527232 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0000.0009 (English), 1/10/2006 06:38:30, 135168 bytes
Driver: C:\WINDOWS\Alcrmv.exe, 2.00.0000.0003 (English), 11/18/2005 04:20:26, 217088 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_71251462&REV_A3\3&241 1E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.0482 (English), 4/5/2005 20:22:30, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.0482 (English), 4/5/2005 20:22:12, 261888 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.0482 (English), 4/5/2005 20:22:02, 208256 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 4/5/2005 20:19:20, 9728 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 4/5/2005 20:19:20, 9728 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0017 (English), 4/4/2005 12:00:26, 32256 bytes
Name: NVIDIA nForce4 Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_71251462&REV_F3\3&241 1E6FE&0&40
Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0552 (English), 8/18/2005 10:52:06, 93568 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 8/18/2005 10:52:08, 289792 bytes
Driver: C:\WINDOWS\system32\idecoins.dll, 1.00.0000.0001 (English), 8/18/2005 10:52:08, 289792 bytes
Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0029 (English), 8/3/2005 07:52:08, 33280 bytes
Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_71251462&REV_F3\3&241 1E6FE&0&38
Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_71251462&REV_F3\3&241 1E6FE&0&30
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (German), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (German), 4/2/2003 13:00:00, 3328 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_71251462&REV_A2\3&241 1E6FE&0&09
Driver: n/a
Name: PCI Standard-ISA-Brücke
Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_00000000&REV_B1\3&241 1E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (German), 4/2/2003 13:00:00, 36224 bytes
Name: PCI Standard-Host-
CPU-Brücke
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C3
Driver: n/a
CPU-Brücke
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C2
Driver: n/a
CPU-Brücke
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C1
Driver: n/a
CPU-Brücke
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&241 1E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 German Final Retail 4/2/2003 13:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 229888 bytes
dpmodemx.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 4/2/2003 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:52 30208 bytes
dpnsvr.exe: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:52 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:54:52 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:54:52 3584 bytes
dpvoice.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 214016 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:52 83456 bytes
dpvvox.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 116736 bytes
dpvacm.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 4/2/2003 13:00:00 54032 bytes
dinput.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 163328 bytes
dinput8.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 186368 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 4/2/2003 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 4/2/2003 13:00:00 395264 bytes
joy.cpl: 5.03.2600.2180 German Final Retail 8/4/2004 00:58:24 69632 bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 4/2/2003 13:00:00 78336 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:34 35328 bytes
dsound.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 74240 bytes
dmusic.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:18 82432 bytes
dx7vb.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 619008 bytes
dx8vb.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:18 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 4/2/2003 13:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:57:24 1028096 bytes
wsock32.dll: 5.01.2600.2180 German Final Retail 8/4/2004 00:57:40 24576 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:57:16 70656 bytes
devenum.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:18 59904 bytes
dxmasf.dll: 6.04.0009.1125 German Final Retail 8/4/2004 00:57:18 499741 bytes
mciqtz32.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:24 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:58:24 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:57:26 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:20 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:34 192512 bytes
qdv.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:34 279040 bytes
qdvd.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:34 386048 bytes
qedit.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:34 563200 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:00 733696 bytes
quartz.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:34 1293312 bytes
strmdll.dll: 4.01.0000.3928 German Final Retail 8/4/2004 00:57:36 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:58:24 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:58:24 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:57:22 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:57:22 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:57:22 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:57:22 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:57:22 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:58:24 154624 bytes
mswebdvd.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:30 205312 bytes
ks.sys: 5.03.2600.2180 German Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 German Final Retail 8/4/2004 00:58:24 130048 bytes
ksuser.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:24 4096 bytes
stream.sys: 5.03.2600.2180 German Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 German Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 German Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 German Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 German Final Retail 8/3/2004 22:58:42 4352 bytes
mstee.sys: 5.03.2600.2180 German Final Retail 8/3/2004 22:58:40 5504 bytes
bdaplgin.ax: 5.03.2600.2180 German Final Retail 8/4/2004 00:58:24 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:58:24 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:57:34 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:58:24 33280 bytes
ipsink.ax: 5.03.2600.2180 German Final Retail 8/4/2004 00:58:24 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:58:24 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 German Final Retail 8/4/2004 00:57:30 1432576 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:24 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:57:30 17408 bytes
kstvtune.ax: 5.03.2600.2180 German Final Retail 8/4/2004 00:58:24 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:24 43008 bytes
kswdmcap.ax: 5.03.2600.2180 German Final Retail 8/4/2004 00:58:24 91136 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 German Final Retail 8/4/2004 00:57:40 51200 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:00 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 000.0009
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
AAC Parser,0x00400000,1,1,aac_parser.ax,1.01.0000.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
OrbUrlSource,0x00600000,0,0,OrbUrlSource.ax,2.2007 .1015.1700
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
OrbNSVSource,0x00600000,0,0,OrbNSVSourceFilter.ax, 2.2007.0626.1430
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.01.0000.0642
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.00 00.0009
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 000.0009
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
DScaler Audio Decoder,0x00800000,1,1,MpegAudio.dll,0.00.0006.000 0
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00. 0000.0009
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
OrbSourceFilter,0x00600000,0,0,OrbSourceFilter.ax, 2.2007.0219.1100
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.000 0
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.24 27.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
WDM Streaming-Daten-Transforms:
Microsoft Kernel-Echounterdrückung,0x00000000,0,0,,
Microsoft Kernel GS Wavetablesynthesizer,0x00200000,1,1,,5.03.2600.218 0
Microsoft Kernel-DLS-Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel-DRM-Audioentschlüsselung,0x00200000,1,1,,5.03.2600.218 0
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming-Capturegeräte:
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.2180
WDM Streaming-Wiedergabegeräte:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming-Mixer:
Microsoft Kernel-Waveaudiomixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming-Systemgeräte:
Realtek AC97 Audio,0x00200000,14,2,,5.03.2600.2180
es kanna uch nur Grakka sein ich habe atm im Spiel nur Grafikkfehler , auf schwarzen farben sind viele verpixelte weiße stellen - da wo es schwarz ist!
