15.12.2010, 14:11
Probleme mit PHP-Datei
Hallo zusammen,
hoffentlich kann mir einer von euch weiter helfen,...
Wenn ich die URL meines Intranets in den Browser eingebe, erscheint folgende Fehlermeldung: Parse error: syntax error, unexpected $end in /usr/share/mediawiki/skins/Modern.php on line 275
Woran liegt das?!
Hier die ganze PHP-Datei: PHP-Code: <?php /** * Modern skin, derived from monobook template. * * @todo document * @addtogroup Skins */
if( !defined( 'MEDIAWIKI' ) ) die( -1 );
/** * Inherit main code from SkinTemplate, set the CSS and template filter. * @todo document * @addtogroup Skins */ class SkinModern extends SkinTemplate { function initPage( &$out ) { SkinTemplate::initPage( $out ); $this->skinname = 'modern'; $this->stylename = 'modern'; $this->template = 'ModernTemplate'; } }
/** * @todo document * @addtogroup Skins */ class ModernTemplate extends QuickTemplate { /** * Template filter callback for Modern skin. * Takes an associative array of data set from a SkinTemplate-based * class, and a wrapper for MediaWiki's localization database, and * outputs a formatted page. * * @access private */ function execute() { global $wgUser; $skin = $wgUser->getSkin();
// Suppress warnings to prevent notices about missing indexes in $this->data wfSuppressWarnings();
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="<?php $this->text('xhtmldefaultnamespace') ?>" <?php foreach($this->data['xhtmlnamespaces'] as $tag => $ns) { ?>xmlns:<?php echo "{$tag}=\"{$ns}\" "; } ?>xml:lang="<?php $this->text('lang') ?>" lang="<?php $this->text('lang') ?>" dir="<?php $this->text('dir') ?>"> <head>
<meta http-equiv="Content-Type" content="<?php $this->text('mimetype') ?>; charset=<?php $this->text('charset') ?>" /> <?php $this->html('headlinks') ?> <title><?php $this->text('pagetitle') ?></title> <style type="text/css" media="screen, projection">/*<![CDATA[*/ @import "<?php $this->text('stylepath') ?>/common/shared.css?<?php echo $GLOBALS['wgStyleVersion'] ?>"; @import "<?php $this->text('stylepath') ?>/<?php $this->text('stylename') ?>/main.css?<?php echo $GLOBALS['wgStyleVersion'] ?>"; /*]]>*/</style> <link rel="stylesheet" type="text/css" <?php if(empty($this->data['printable']) ) { ?>media="print"<?php } ?> href="<?php $this->text('stylepath') ?>/<?php $this->text('stylename') ?>/print.css?<?php echo $GLOBALS['wgStyleVersion'] ?>" /> <!--[if lt IE 7]><meta http-equiv="imagetoolbar" content="no" /><![endif]--> <?php print Skin::makeGlobalVariablesScript( $this->data ); ?> <script type="<?php $this->text('jsmimetype') ?>" src="<?php $this->text('stylepath' ) ?>/common/wikibits.js?<?php echo $GLOBALS['wgStyleVersion'] ?>"><!-- wikibits js --></script> <!-- Head Scripts --> <?php $this->html('headscripts') ?> <?php if($this->data['jsvarurl' ]) { ?> <script type="<?php $this->text('jsmimetype') ?>" src="<?php $this->text('jsvarurl' ) ?>"><!-- site js --></script> <?php } ?> <?php if($this->data['pagecss' ]) { ?> <style type="text/css"><?php $this->html('pagecss' ) ?></style> <?php } if($this->data['usercss' ]) { ?> <style type="text/css"><?php $this->html('usercss' ) ?></style> <?php } if($this->data['userjs' ]) { ?> <script type="<?php $this->text('jsmimetype') ?>" src="<?php $this->text('userjs' ) ?>"></script> <?php } if($this->data['userjsprev']) { ?> <script type="<?php $this->text('jsmimetype') ?>"><?php $this->html('userjsprev') ?></script> <?php } if($this->data['trackbackhtml']) print $this->data['trackbackhtml']; ?> </head> <body <?php if($this->data['body_ondblclick']) { ?> ondblclick="<?php $this->text('body_ondblclick') ?>"<?php } ?> <?php if($this->data['body_onload' ]) { ?> onload="<?php $this->text('body_onload') ?>"<?php } ?> class="mediawiki <?php $this->text('nsclass') ?> <?php $this->text('dir') ?> <?php $this->text('pageclass') ?>">
<!-- heading -->
<div id="mw_header">
<div id="metamenu"> <ul-inhalt> <a style="color:#000000" title="Startseite" href="http://info.keimfarben.de/mediawiki/index.php/Hauptseite">Startseite</a> <a style="color:#000000" title=Seitenübersicht" href="http://info.keimfarben.de/mediawiki/index.php/Seiten%C3%BCbersicht">Seitenübersicht</a> <a style="color:#000000" title="Suche" href="http://info.keimfarben.de/mediawiki/index.php/Spezial:Suche">Suche</a> <a style="color:#000000" title="Anmelden" href="http://info.keimfarben.de/mediawiki/index.php/Spezial:Anmelden">Anmelden</a> <a style="color:#000000" title="Kontakt" href="http://info.keimfarben.de/mediawiki/index.php/Kontakt">Kontakt</a> </ul-inhalt> </div>
<!-- search --> <div id="p-search" class="portlet"> <h5><label for="searchInput"><?php $this->msg('search') ?></label></h5> <div id="searchBody" class="pBody"> <form action="<?php $this->text('searchaction') ?>" id="searchform"><div> <input style="font-size:12px; width:160px; id="searchInput" name="search" type="text" value="Suchbegriff hier eingeben" onblur="if(this.value=='')this.value='Suchbegriff hier eingeben...';" onfocus="if(this.value=='Suchbegriff hier eingeben')this.value='';" <?php echo $skin->tooltipAndAccesskey('search'); if( isset( $this->data['search'] ) ) { ?> value="<?php $this->text('search') ?>"<?php } ?> /> <input type='submit' name="fulltext" class="searchButton" id="mw-searchButton" value="<?php $this->msg('searchbutton') ?>"<?php echo $skin->tooltipAndAccesskey( 'search-fulltext' ); ?> /> </div></form> </div><!-- pBody --> </div><!-- portlet -->
</div> <div class='mw_clear'></div>
<div id="mw_contentwrapper"> <div id="mw_content"> <!-- contentholder does nothing by default, but it allows users to style the text inside the content area without affecting the meaning of 'em' in #mw_content, which is used for the margins --> <div id="mw_contentholder"> <font size=2> <div class='mw-topboxes'> <?php if($this->data['newtalk'] ) { ?><div class="usermessage mw-topbox"><?php $this->html('newtalk') ?></div> <?php } ?> <?php if($this->data['sitenotice']) { ?><div class="mw-topbox" id="siteNotice"><?php $this->html('sitenotice') ?></div> <?php } ?> </div>
<div id="contentSub"><?php $this->html('subtitle') ?></div>
<?php if($this->data['undelete']) { ?><div id="contentSub2"><?php $this->html('undelete') ?></div><?php } ?> <?php if($this->data['showjumplinks']) { ?><div id="jump-to-nav"><?php $this->msg('jumpto') ?> <a href="#column-one"><?php $this->msg('jumptonavigation') ?></a>, <a href="#searchInput"><?php $this->msg('jumptosearch') ?></a></div><?php } ?>
<?php $this->html('bodytext') ?>
<?php if($this->data['catlinks']) { ?><div id="catlinks"><?php $this->html('catlinks') ?></div><?php } ?> <div class='mw_clear'></div> </div><!-- mw_contentholder -->
</div><!-- mw_content --> </div><!-- mw_contentwrapper -->
<div id="mw_portlets"> <!-- other portlets --> <?php foreach ($this->data['sidebar'] as $bar => $cont) { ?> <div class='portlet' id='p-<?php echo Sanitizer::escapeId($bar) ?>'<?php echo $skin->tooltip('p-'.$bar) ?>> <h5><?php $out = wfMsg( $bar ); if (wfEmptyMsg($bar, $out)) echo $bar; else echo $out; ?></h5> <div class='pBody'> <ul> <?php foreach($cont as $key => $val) { ?> <li id="<?php echo Sanitizer::escapeId($val['id']) ?>"<?php if ( $val['active'] ) { ?> class="active" <?php } ?>><a href="<?php echo htmlspecialchars($val['href']) ?>"<?php echo $skin->tooltipAndAccesskey($val['id']) ?>><?php echo htmlspecialchars($val['text']) ?></a></li>
<?php } ?> </ul> </div><!-- pBody --> </div><!-- portlet -->
<!-- toolbox --> <div class="portlet" id="p-tb"> <?php if($this->data['loggedin']) { ?> <h5><?php $this->msg('toolbox') ?></h5>
<div class="pBody"> <ul> <?php if($this->data['notspecialpage']) { ?> </li> <?php if( $this->data['nav_urls']['recentchangeslinked'] ) { ?>
<?php } } if(isset($this->data['nav_urls']['trackbacklink'])) { ?> <li id="t-trackbacklink"><a href="<?php echo htmlspecialchars($this->data['nav_urls']['trackbacklink']['href']) ?>"<?php echo $skin->tooltipAndAccesskey('t-trackbacklink') ?>><?php $this->msg('trackbacklink') ?></a></li>
<li id="feedlinks"><?php foreach($this->data['feeds'] as $key => $feed) { ?><span id="feed-<?php echo Sanitizer::escapeId($key) ?>"><a href="<?php echo htmlspecialchars($feed['href']) ?>"<?php echo $skin->tooltipAndAccesskey('feed-'.$key) ?>><?php echo htmlspecialchars($feed['text'])?></a> </span> <?php } ?></li><?php }
foreach( array('log', 'emailuser', 'upload', 'specialpages') as $special ) {
if($this->data['nav_urls'][$special]) { ?><li id="t-<?php echo $special ?>"><a href="<?php echo htmlspecialchars($this->data['nav_urls'][$special]['href']) ?>"<?php echo $skin->tooltipAndAccesskey('t-'.$special) ?>><?php $this->msg($special) ?></a></li> <?php } }
if(!empty($this->data['nav_urls']['print']['href'])) { ?> <?php }
if(!empty($this->data['nav_urls']['href'])) { ?> <li id="t-permalink"><a href="<?php echo htmlspecialchars($this->data['nav_urls']['href']) ?>"<?php echo $skin->tooltipAndAccesskey('t-permalink') ?>><?php $this->msg('permalink') ?></a></li><?php } elseif ($this->data['nav_urls']['href'] === '') { ?> <li id="t-ispermalink"<?php echo $skin->tooltip('t-ispermalink') ?>><?php $this->msg('permalink') ?></li><?php } ?> </ul> <?php } ?> </div><!-- pBody --> </div><!-- portlet -->
<div id="p-lang" class="portlet"> <h5><?php $this->msg('otherlanguages') ?></h5> <div class="pBody"> <ul> <?php foreach($this->data['language_urls'] as $langlink) { ?> <li class="<?php echo htmlspecialchars($langlink['class'])?>"><?php ?><a href="<?php echo htmlspecialchars($langlink['href']) ?>"><?php echo $langlink['text'] ?></a></li> <?php } ?> </ul> </div><!-- pBody --> </div><!-- portlet -->
<!-- personal portlet --> <div class="portlet" id="p-personal"> <h5><?php $this->msg('personaltools') ?></h5> <div class="pBody"> <ul> <?php foreach($this->data['personal_urls'] as $key => $item) { ?> <li id="pt-<?php echo Sanitizer::escapeId($key) ?>"<?php if ($item['active']) { ?> class="active"<?php } ?>><a href="<?php echo htmlspecialchars($item['href']) ?>"<?php echo $skin->tooltipAndAccesskey('pt-'.$key) ?><?php if(!empty($item['class'])) { ?> class="<?php echo htmlspecialchars($item['class']) ?>"<?php } ?>><?php echo htmlspecialchars($item['text']) ?></a></li> <?php } ?> </ul> </div> </div>
<!-- languages --> </div>
<div id="sidebar"
<div id="sidebar2"> <ul-inhalt> <b><a title="Dokumente">Dokumente</a></b> <br> </ul-inhalt> </div>
<div id="sidebar2i"> <ul-inhalt> <a title="Formulare" href="http://info.keimfarben.de/mediawiki/index.php/Formulare">Formulare</a> <br> <a title="Vorlagen" href="http://info.keimfarben.de/mediawiki/index.php/Vorlagen">Vorlagen</a> <br> <a title="Telefonlisten" href="http://info.keimfarben.de/mediawiki/index.php/Telefonlisten">Telefonlisten</a> <br> <a title="Vertrieb Inland" href="http://info.keimfarben.de/mediawiki/index.php/Vertrieb_Inland">Vertrieb Inland</a> <br> <a title="Vertrieb Export" href="http://info.keimfarben.de/mediawiki/index.php/Vertrieb_Export">Vertrieb Export</a> </ul-inhalt> </div>
<div id="sidebarprodukte"> <ul-inhalt> <b><a title="Produkte">Produkte</a></b> <br> </ul-inhalt> </div>
<div id="sidebar2produkte"> <ul-inhalt> <a title="Printmedien" href="http://info.keimfarben.de/mediawiki/index.php/Printmedien">Printmedien</a> <br> <a title="Produktprogramm" href="http://www.keimfarben.de/de/produktprogramm_2010/">Produktprogramm</a> <br> <a title="Technische Merkblaetter" href="http://www.keimfarben.de/de/technische_merkblaetter_2010/">Technische Merkblätter</a> </ul-inhalt> </div>
</div>
</body></html>
Danke für eure Hilfe!
Viele Grüße
Shanai
